- Apr 27, 2010
- Bethlehem, Georgia
Mercury/Mariner Standard Outboard Wiring Color Code
Color Where Used / Function
Black - All Ground
Brown -Reference Electrode MerCathode System
Orange -Anode Electrode MerCathode System
Lt. Blue/White Stripe -Trim UP Switch
Lt. Green/White Stripe -Trim DOWN Switch
Brown/White Stripe -Trim Sender to Trim Gauge
Purple/White Stripe -Trim "Trailer" Switch
Gray -Tachometer Signal
Black/Yellow Stripe - Shorting or Stop Circuit
Pink - Fuel Sender to Gauge
Red - Unprotected Wire from Battery
Red/Purple Stripe - Protected (Fused) Wire from Battery
Red/Purple Stripe - Protected (12 Volt +) to Trim Panel Control
Purple - Ignition (Switch) to 12 Volt Positive
Tan - Temperature Switch to Warning Horn
Tan - Temperature Sender to Temperature Gauge
Tan/Blue Stripe - Temperature Switch to Warning Horn
Yellow - Starter Solenoid to Starter Motor
Yellow - Starter to Regulator (Charging Circuit)
Yellow/Red Stripe - Start Switch to Start Solenoid to Neutral Start Switch
Yellow/Black Stripe - Choke (Enrichener System)
Green with Color Stripe - Switch Box to Coil - Striped and Numbered
White/Black Stripe - Bias Circuit (Switch Boxes)
The ABYC Recommended Colors
Yellow/Red - Starting Circuits
Brown/Yellow or Yellow - Bilge Blowers
Dark Grey - Navigation Lights & Tach Signals
Orange - Accessory Feeds
Brown - Pumps
Purple - Instrument Feeds
Dark Blue - Cabin and instrument Lights
Light Blue - Oil Pressure
Tan -Water Temperature
Pink -Fuel Gauge Sender
Found on the Mercury website - http://www.mercurymarine.com/servic...intenance/faqs/outboards/?category=electrical
Black - All Ground
Brown - Pumps
