- Jan 14, 2010
- Lake Hartwell, SC
What type oil are you running in your motor? BRP brands or a substitute? If you are running a TCW3 dino oil BRP XD-30 is a good choice in the smaller carbed motors. In the larger displacement carb motors I recommend using BRP's XD-50 it is a semi-synthetic blend and has an agent to help remove carbon in your motor called Carb-X. The best oil to run in a DFI or E-tec is the XD-100 full synthetic. You can ask your local BRP dealer if he has any of the above oils in bulk. If he does you can save some substantial jack by bringing him a clean gallon jug for him to pump it into.
If BRP products aren't close to you QuickSilver Premium Plus is a good alternate. Pensoil full synthetic is also a good choice.
