XBraid V12 Fluorocarbon Leader – A Leader in Leaders
Kevin
Senior Fisheman
Craig, Colorado
Best Catch
12lbs
Charger
XBraid is here with its most technologically advanced leader to date, with the new XBraid V12 Fluorocarbon Leader. This is a 100% fluorocarbon leader that is thinner, stronger, and clearer than ever. XBraid has employed a proprietary manufacturing process to create this new leader. Making it 1.3X stronger than previous fluorocarbon leaders. All the while still having a thinner leader diameter as well. Beyond the new thinner diameter and increased line test is the optical clarity of the leader, the pinnacle advancement in it. V12 uses elite clarity resin and a sophisticated extrusion process to deliver an incredibly smooth finish and a clear leader. Additionally, V12 leader’s resin makes it incredibly abrasion resistant, to the point of only being bested by wire, but still has reduced memory and coiling.
“It starts with premium clarity fluorocarbon resin,” said DAIWA Field Marketing Manager Chris Martin. “XBRAID’s advanced extrusion process then renders a slim profile without sacrificing any strength, finishing with a leader line that is basically invisible in the water with an incredible refractive index.”
The 100% fluorocarbon V12 leader is available in clear in the line tests from 2 lb to 25 lb in 33-yard spools. MSRP is set at $19.99 per spool.
XBraid V12 Fluorocarbon Leader Key Features
  • 100% fluorocarbon
  • Made from the clearest fluorocarbon resins
  • Proprietary extrusion process
  • Slim profile
  • Exceptional hardness resists coiling
  • Highly abrasion-resistant
  • Low-stretch
  • Incredible knot strength
  • Breaking Strengths – 2- to 25 lb Test Strengths
  • Sizes – 33-yard Spools
  • Color – Clear
  • MSRP – $19.99
  • Available – Available Now
The post XBraid V12 Fluorocarbon Leader – A Leader in Leaders appeared first on OutdoorHub.
