920 ProXP
Big and fast have never truly been achieved until now…
The Phoenix 920 Pro XP is the closest thing to perfection on the water today. It’s as wide as the 921, and one foot shorter. It gives you the width, storage, and comfort that you expect in a big boat along with the speed, handling, and maneuverability of a 20-footer. Couple all of this with industry-best standard features such as stainless-steel hardware, integrated net storage, and the capability to flush-mount big screen electronics and you have a head-turning, boat-passing, bass-catching machine!
Standard Features
Popular Options
Length:20' 6"Beam:96"Fuel capacity:50 gal.Max HP:200-250 HPWeight (approx):1850 lbs.Livewell Cap:44 gal.
DETAIL GALLERY
View More >
COPYRIGHT © 2020 PHOENIX BASS BOATS
Standard Features
- All Composite Construction Including Transom & Stringers
- Hydraulic Tilt Steering
- Custom Steering Wheel
- 10″ Adjustable Jack Plate
- Trim At The Helm
- Hot Foot Throttle W/ Adj. Slide
- Lowrance Live HDS 7 Flush In Bow
- Lowrance Live HDS 9 Flush In Console
- Lowrance 2-1 Active Image Transducer
- Lowrance NMEA Harness W/ Point 1 Antenna
- Lowrance Ethernet Cable
- Full Instrumentation
- Passenger Side Rod Box / Ramp
- Recessed Trolling Motor Foot Pedal
- Auxiliary Power Outlet
- USB Power Outlet
- Passenger Grab Handle & Foot Rest/Brace
- Rod Buckles
- LED Courtesy Lights
- LED Compartment Lights
- Snake Light
- Port Side Rod Organizer
- Stainless Phoenix Logo Package
- Console Storage Box w/ Cup Holders
- 1 Fold Down Seat / 1 Bike Seat & Pwr Pro Pole
- Custom Cover
- Drop In Rear Storage Trays
- Phoenix Culling System
- Phoenix Integrated Wiring System
- Pro Tech Padded Deck
- Under Seat Net Storage
- Tool Holder in Bow
- LED Navigation Lights
- Stainless Steel Lid Assist
- Minn Kota Fortrex 112 36v 45”
- 4×10 Battery Charger
- Livewell Recirculation System
- Livewell Pump Out System
- LED Livewell Lights
- Two 1100 GPH Auto Bilge Pump
- Stainless Steel Pull Up Cleats
- Stainless Locking Latches
- Stainless Trim on Tool Holders
- Tandem Axle Trailer w/ Disc Brakes
- Gatorhyde Finish
- Aluminum Step Pads
- Custom Aluminum Wheels w/ Radial Tires
- Ratchet Tie Downs
- Lazer Cut “Phoenix” Step Pads
- OEM Grade Vault Hybrid Lubrication System
- Bow Step Pads
- Swing Tongue
- Matching Spare
- LED Trailer Lights
Popular Options
- Gen 3 Helix 10 SI on Dual Dash at Console
- Gen 3 Helix 10 GPS on REM Gimbal at Bow
- Humminbird Ethernet Cable
- Minn Kota 112 36V 45″
- Port Black 8′ Blade Power Pole
- Starboard Black 8′ Blade Power Pole
- Mercury Stainless Steel Prop
- Paint over Gatorhyde
- Stainless Steel Fenders
- Shocks
- Velocity Wheel Upgrade
DETAIL GALLERY
View More >
