The Cougar FTD (Full Team Deck) began a wave for Bass Cat in terms of efficiency and performance. It shares the proven FTD hull that has been refined over time. Our latest design had a couple inches added to the beam for the perfect platform to pitch or cast from. The center storage allows you to access your gear without moving your deck rods.
The console is clean and comes with either cafe or large windscreens. It can accommodate 12 inch units with additional mounting options that includes our new dual, side-by-side mounting system. With twin rear storages, sub-storage under the premium euro style bucket seats, and dual coolers, you’ll always have an organized boat with storage to spare.
Every square inch of this boat was carefully planned to enhance your ability to compete under any conditions. Our Cougar FTD has been a solid performer and will continue to make its mark as a tournament predator.
Cougar FTD Special Package Details Here
SPECIFICATIONS
- Length - 20'4"
- Min Storage Length - 26'1"
- W/Swing Away Tongue - 23'2"
- Beam - 94"
- Approx Boat Weight - 1805lbs
- Fuel Capacity - 52gal (36gal std on Special Package)
- Max H.P. Range - 200-300
Engine and Controls (non Verado)
Two (2) Hummingbird Helix 7's
Minn Kota Fortrex 80 - 45"
Minn Kota - 3 Bank Battery Charger
Cranking Battery Pro-Guide AGM CA1050
Lighted Hand Rails
Integrated Stainless Ladder
Dual (2) 1000 GPH Bilges with Automatic
Slidemaster Jackplate
Boat Ventilation System (12 volt)
Battery Tender Trolling Motor Plug
Integrated Push Button Deck Lighting
48 Volt Gauge (Bow)
Interactive Digital Panel, Pump In/Out, Security, & Lighted Boxes
One Butt Seat with Pro Pole
One Fold Down with 13" Extension
52 Gallons of Fuel - 2 tanks 2x26 = 52 gal
*May be 5% less with opacity value
Quicksilver Matched Analog Gauge Package
Southco Latches
Plano Tackle Trays ABS
24 Ounce Carpet
Dip Net Scabbard
Two Rod Boxes - One Organizer
Pliers holder on front deck
Dual Rod Straps - Bass Cat
Passenger Rod Stay
Master Power (2) - At Dash and Crank Battery Breaker
Mooring Flip Cleats (2) at Consoles, plus docking Cleats
Tinned Wire - 6 Gauge trolling
Windscreen (choice - large or small)
Removeable Rear Deck Lids
Engine Matched Propeller
Stainless Cup Holders
Vinyl Ester Resin on 40%-all outer laminate
3-R&R Aluminum Battery Trays
Colored Nose Cap
Added Stripe - I2 or Hull SI2 (mini)
Two Fully Insulated Ice Chests
Foam Filled Stringer System
Trailer Features
4" C Channel frame - US Steel - Tandem
Five (5) cross members
Welded to fit construction
Fiberglass Fenders
Pivot Tongue
PPG Clear Coat (1)
LED Lights
15" Aluminum Wheels & Black Wall Tires
Torqueflex Axles Vault Hubs, one brake axle
Dual Axle Brakes
Fiberglass Step
Vault Hubs
IMCO Tie Downs
